i'll look on ebay for some forged, and i thought keeping the LCA higher would be better, i was trying to keep as much mid range as i could, and the 114 had good looking nubers. i'll mess around with some more numbers, and keep the duration under 235
took you advice and kept 112, and under 235
LCA112
225/230
600/650
intake center 114
400+ft-lbs 2k-7k peak 505@5k
peak hp 567@6500
my compression ratio should be 10.8, if i did all my math correct
