B&B Front A-Arm Lengths
Can anyone tell me the length of the front upper and lower A-arms for the B&B Coil-Over setup? I bougt after-market arms and want to make sure they are not too long. It seems that my tires stick out a little too far and rub, and the backspacing is supposed to be right on. If you could, measure perpindicular from the center of pivot at the frame connection to the center of the ball joint.
If they are the same size as the B$B's, is there a shorter A-arm assembly available to get better clearances?
Thanks,
Darren
