Contemporary fan assembly
The fan assembly off 3152 is available. I'm guessing these were all fab'd the same, two bolts at 5.75" on the right side one bolt on the lower left. It nestles in between the rack and pinion tube and the radiator mounted on brackets welded to the radiator housing.
It works fine, no breaks or repairs. It was fine with a 375 HP 428 but needs to be on early and often with the 427. The chassis has 20k miles since 1988.
If someone needs it I'm looking for interesting trades. (707) 235.6639
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
