Thread: Clutch "issues"
Old 10-30-2004, 01:54 PM
Tony Radford Tony what is the air gap between the disc and pressure plate or flywheel when you have it engaged? On an alum flywheel, .060" to .080" in the min spec. It may be larger with an iron disc. Call Mcloed and ask Red. Has far as the chatter that's a given. Titlon has a 3 disc clutch with the same problem either in or out, NO SLIPPING IT. A high preformance clutch for a 3400 lb car is all your car should need. I would take that one out and put a HD in there with the spring hub on the disc. Set the air gap on the pressure plate to .040-.055" and your problem will be gone. Give me a call if you want to talk about this. 1-732-254-3536. Rick Lake
