Old 10-30-2004, 10:26 PM
cobra427mnsi cobra427mnsi is offline
Cobra Make, Engine: Classic Roadster with 427 center oiler
I just went through a similar problem. Recently, converted from the old Ford electronic ignition to an MSD 6AL ignition and MSD distributor. I also changed over to the alternator with the internal regulator. I did all this to clean up the firewall. Got rid of ballast resistor, voltage regulator and ignition module and alot of wires.
Anyway, after all that work, I noticed that the voltmeter showed 14 volts sometimes and around 10 volts other times. It was hit and miss. Very frustrating. This happened for about two weeks or so. Then, finally, no charge at all, a steady 10 volts.
I replaced the brand new alternator (still under warranty) and have had a steady 14 volts since. No problems for a week now.
So, from my experience, I'll bet it is your alternator going bad or at least the voltage regulator.
Paul
life is short: eat dessert first !
