Kip, congratulations on your win, you really drove well.
I was confused at the way my car would plow after letting up, it dawned on me on the way home that it must be the differential. I suspect it might be locked up as I'm into those sweeping turns and cause the car to want to go straight. And here I was making custom sway bars and installing spherical bearings. I'm going to find a differential guy and have a Torsen put in.
BTW, if you want to match drill the holes in your damper let me know, I can put some in the same size and depth if you want to stop by the shop some afternoon. Your engine builder should be slapped upside the head with a wet Salmon.
Randy, were are the pictures of your fish?
