jerry
You can get standard mounts from NAPA. That's what I did for my 351. I thought I wanted to reduce the amount of engine torque movement. Thought I would go with the Polyurethane mounts, not available for "70 351's. There is a lot of stuff on the threads about mounts. Do a search.
I decided to buy some from Mite Mounts in Calif. They said that they reduce the amount of movement. After spending $125 and putting them on, they only reduce the amount slightly. A bit disappointed. Good Luck
Jim
