Thread: Side pipes
Old 11-04-2004, 08:26 AM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Bruce,
You'll find out real fast that every time you drive your car it WILL get louder and louder as it blows the glass out of those 10$ glasspacks. I had the same setup. Your headers should be 2" pipes and your sidepipes should be the same size. But most Lonestars' sidepipes are only 1 3/4" and it chokes your engine quite a bit. I installed a set of 2" sidepipes from finishline after having them ceramic coated. Instead of glass packs, they have an auger type muffler that dosn't blow out and is a little quieter. Also, the turnouts of your pipes are probably 3", the ones from Finishline are 3 1/2". You're not too far from me, if you like give me a call and you can check them out .
Tim 972-489-6376
" It ain't no big deal"
