Thread: Boot Gas struts
Old 11-04-2004, 03:42 PM
David Hodgson's Avatar
David Hodgson David Hodgson is offline
NASSTY
If your carefull with the mounting angles, you could set up the strut so at it compressed position it is just going over centre and has a nuetral push.
My boot stay is currently to one side at the rear, gets in the way a bit, but one to the side shouldn't hurt as the boot is usually open for a short time. Some guys use the ratchet type like on Holden panel van rear windows.
As for the bonnet, if your using a stay rod, make sure it it locks into bonnet in a tear drop hole or somehting, not just like a peg in a hole as the wind can lift the bonnet, stay drops out, and slam goes the bonnet.
SLIPRY
