I find all of this old news since we have already built about 15 Genesis engines and short-blocks. We have built two aluminum block engines as well. We have also built a Pond Motorsports aluminum block 427 for a customer as well. We inspect all of our blocks by pressure checking, crack checking and probing in our RMC CNC block machining center to the original Ford blueprints.
If you want a nice FE Ford crate engine at a great price, all you have to do is pick up the phone and call. As far as the blocks, we have 10 Genesis cast iron blocks in stock, 5 Shelby aluminum blocks in stock, 4 standard bore and one large bore. We have more coming as well. If you want to be a player in this market you have to step up to the plate and get with the program. Most shops waite till the customer gives them a deposit and then try to get this stuff and then they are waiting. We buy it when it is available and the customer does not have to waite.
We have FE crate 427 engines that start at 13,995.00 and go up from there. SWe will also have the Genesis aluminum blocks as well as the Pond Motorsports steel and aluminum blocks as well.
As far as the oiling system on these blocks which has been beat to death on this sight all of the blocks have good oiling systems when a few modifications are performed to make them the best they can be. I have no problem with the side oiloer or the Shelby priority oiling system.
Now that you know who has the parts just give a call with your needs. We will sell you a machined block, crank kit, CNC heads and any other part you want if you want to do it your self or we can build complete. The future is here. Thanks Keith Craft
Keith C
