Thread: Engine cuts out
Old 11-07-2004, 07:35 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
The tank may have a filter on the pick up in the tank. If becoming plugged then the additional weight of fuel with a full tank helps push through occluded filter. You could also have a cracked /broken hose in tank that is exposed when fuel level is lower in tank. Bet you get to drop the tank to fix this one.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
