Originally posted by David Hodgson
Since we're on glassing and doors, my door skins are sucked in (concave and not flat). Whats the best way to fill? I thought layers of glass, is there a better way?
G'day David.
I'm assuming your outer skins are already bonded to the door frame?
If so, I've been told to sand and bog up the cavity then block back flat. Bog is resign with powder instead of glass so if the surface is prep'd properly it will never fall out.
When I glassed my outer skin to the door frame, I packed some cardboard along the middle of the frame, in three places, to help reduce the concavity of the door. (The cardboard absorbs the resin and becomes solid) This worked well but there is still some concavity there which I will fix as described above.
