Opps. Sorry, I forgot to mention the M3's diff. You are correct, it will help lap times as well as the brakes.
Surely Backdraft must be searching for a fix to this problem without requiring their clients to upgrade suspension, right
I have to disagree here. The differential supplied with the car is the standard differential that comes standard in the suspension package used in the car. It's not "A Problem" that needs fixing. It's one of the items that allows the car to be priced as it is. I've driven or raced at least 2 dozen BDR cars and I personally believe that the 80/20 stock diff is very addiquate for putting power down. Both tires pull.
Hope this helps.
Boudy
