Old 11-12-2004, 01:26 PM
MIKE SCHULZ's Avatar
MIKE SCHULZ MIKE SCHULZ is offline
Cobra Make, Engine: Contemporary 427 CCX 3627 ,TKO 600 RR,TWM 58mm DFI
Default Importing into Canada
Ryan;Theres good news and bad news!...The Good news is that you can import a "Kit" car into Canada - such as a Cobra. The bad news is that it HAS to come over in pieces.I recently brought over a Contemporary Cobra and had to go through this ordeal myself!. The frame has to be stripped down so that it DOE NOT contain even one bolt attached to it. If they do find that one bolt attached (anywhere)- The Dept of Transportation will be called and the owner of this frame (You) will have to provide proof of Manufactures standards so that your Vehicle will meet Government codes and specifications.Believe me - you don`t want to go through that!.I am in B.C Canada also and researched this issue well before I bought mine. All the suspension and other trinkets came all on one shipment ( Frame too) with no problems getting through.Once the frame is completely stripped down - One could call it a "Jig" or "Template" to the border people and pay your taxes ...and be on your way.The Border people do not like "Kit" cars and it`s next to impossible to get it across otherwise.Good luck Sir!...Mike
