Old 11-13-2004, 02:57 PM
relaxinrob's Avatar
relaxinrob relaxinrob is offline
Cobra Make, Engine: FFR Daytona Coupe done to replicate CSX-2299 at the '64 LeMans
Get an FI system off of a 5.0 Explorer. They flow very well. Change out the injectors to 42# and get an 80mm Pro-M mass air and 80mm Accufab throttle body. Don't forget to port-match the intake with the gaskets.....takes time, but worth it. You will need to get a Tweecer RT system to re-calibrate your EEC or you can have your dyno guys cut a chip, but then you're locked into one setting.....the Tweecer is a better way to go.
Good Luck
Replicas are the highest form of flattery!
http://www.rehobothproperties.com/coupe.htm
