Thread: TOB fluid
Old 11-13-2004, 04:55 PM
Joe Prochazka Joe Prochazka is offline
Cobra Make, Engine: Unique 427SC-Junkyard 390 with a few aluminum parts-toploader
Default TOB fluid
Well, I just got my new flywheel and upgraded Mcleod hydraulic TOB installed. Trans is back in and tomorrow I will bleed the TOB and then test drive.
Is the Wilwood High Temp brake fluid compatible with the Mcleod seals? The first time around I used DOT 3 and it turned black pretty quick.
If the Willwood will work OK then I would prefer to use that.
Thanks
