dvcobra, I'm not sure why your pedal would have moved closer. The car calls for a 1974 to 1978 Mustang II booster and they were all the same. I have seen a couple of the boosters that the rebuilder had added an extra bracket that moved the booster away from the firewall which would bring the pedal closer to the floor. I'm not sure what to tell you about moving the pedal back where it was. I usually set the brake pedal about 3" higher than the gas. That way there is no chance of hitting the gas at the same time (which I have seen happen). Actually you can't change the brake pedal, you must move the gas pedal with the cable length.
Don
