Old 11-15-2004, 05:16 PM
Daniel Jones Daniel Jones is offline
> Now that I think about it, I guess less weight IS easier to push!!
Yup. The torque converter is a fluid coupling so the heavier the vehicle,
the more it slips before the vehicle starts moving.
> With the X303 cam and lifters, is this a bad choice??
The X303 cam will pick up 20+ HP over a stock 5.0L HO cam but with stock
hydraulic roller lifters, it'll peak before 6000 RPM. Depending on the
springs and lifter tolerances, you might get to 6500 RPM before the valves
float but it'll be hit or miss. With a roller cam, you do not want to
float the valves, it'll beat the little needle bearings to death.
> I was planning on going with 1.7 roller rockers to get a little more
> lift....good/bad?
Depends upon your valve springs and piston-to-valve clearance. With my
stock forged pistons, I wouldn't probably wouldn't have the clearance.
Unless you install stronger springs, the higher ratio rockers may float
the valves at a lower RPM.
> The heads........That sounds like a good price. I did plan on using the stock
> heads but they need all kinds of work! I also wanted to get some porting done
> on them. I suppose if I'm going to do all that I might as well go for
> something good!?!?! What type of power increase can I expect from the GT 40
> heads? Can I use them out of the box, get great results and not have to
> upgrade later??
The GT40 heads are worth a good 40 HP boost over the stock 5.0L HO heads.
There are better heads out there like the AFR's but the cost is higher.
The GT40's will support your HP goals and still fit the budget.
> The crank on this engine is toast (I think) One of the rod journals has some
> deep grooves, looks pretty bad. SO, I now plan on getting a new crank.
If you hadn't already got the pistons, I would have suggested one of the
budget stroker kits if you have to buy a crank anyway. Nice thing about
a stroker crank is that you can get good compression even with 64cc heads.
Check the rods for heat discoloration.
> I'm going to build the bottom end as good as I can(within reason) with all
> new parts.....Crank, pistons, rods, bolts.....
The stock crank is balanced for 50 oz-in and is the weak link. You can
rebalance the crank with a bit of Mallory metal to 28 oz-in which is
safer at the RPM you plan but it means getting a 28 oz-in balancer and
AOD flexplate.
> and probably get the GT 40 heads instead of wasting my money on the stock
> junk heads.
I would have done that when I rebuilt my 5.0L HO but my heads needed
only a valve job and valve springs. Dad has a valve grinder so the
valve job was free.
> I really want some rpm's out of this thing so I need to work out the details
> of getting to at least 6500rpm's.
If you stick with hydraulic roller cam, I'd sell the X303 and call
Rick Anderson at Anderson Ford Motorsport. He's done a lot of work on
high RPM lobe profiles that work with the Ford roller lifters. A friend
of mine does a lot of dyno work with Anderson and they've probably had a
dozen different custom cams in his 5.0L (now a 347). He can now turn
7600 RPM on stock Ford hydraulic roller lifters. Rick is secretive
about his grinds and won't tell you the specs until you actually by the
cam but trust his judgement on the grind and you'll be happy.
> If you had a 302 and wanted: 300-350 h.p. 6500rpm's
Cam as above. GT40 aluminum heads, an RPM air gap intake, windage tray
(Ford Motorsport Boss 302 tray for front pan, MPG tray for 5.0L dual
hump pan), roller timing chain, blueprinted stock volume oil pump or
Mellings high volume pump (the high volume pump might be necessary with
the Anderson cam), high compression pistons. A Victor Jr might make a
few more HP up top but will give up some torque down low. Might not
matter with your light roadster.
Note that Ford rates it's GT40 aluminum headed 302 crate motor at
345HP with a B303 cam, so your HP goal is entirely reasonable.
That's with the X303 heads. With the Y302 heads, it's down 20HP.
> and a completely "Nasty" sounding motor that turns heads
That's mainly a lobe center/duration and muffler thing.
> What parts would you put in it, on a budget , to get there???
What compression do your pistons yield with 64cc heads?
What are the lift limits (due to depth of valve notch reliefs)?
Dan Jones
