Old 11-15-2004, 07:39 PM
pneall's Avatar
pneall pneall is offline
Gav,
I used Ians pedals but offset them to the left to give better space for accelerator. Offset was about 25mm which still lets you get your foot behind the clutch pedal when cruising. Ians new clutch is offset at the pivot point which allows rose joint connection to cylinder. Much neater than early ideas.
For falcon pedal ($17.00) slightly modified works ok but I plan to make up fabricated unit which will work and look better.
Mike Murphys gallery has photo of offset pedal arrangement.
Phil
