Old 11-16-2004, 04:47 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
I view the rubber gasket or protection on the top of the turkey pan to be somewhat problematic and confusing. The reason is this. When you blip your throttle with the hood open, watch what happens to the engine and its reaction to the torque. It moves as one engine mount compresses and the other expands. And one edge of the turkey pan dips and the other edge raises up with the torque.
With the rear wheels engaged, this torque is even more pronounced. If you snug up your turkey pan close to the closed engine compartment lid you will indeed be abrading the inside bottom of the lid. What you will need will be an abrasion guard.
Thus, it is my feeling that sometimes what many think is an air gasket for the turkey pan is really an abrasion guard for the engine compartment lid.
If you want an air tight insulation for the turkey pan, you should do this with foam fabricated in such a way to make a very flexible seal which can withstand air flow at speed as well as engine movement.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
