Thread: Finally
Old 11-20-2004, 03:44 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
My BDR was backfiring at Gainesville. Reg said he would fix it for me at Garlits on Saturday. I said "why would I want to do that?" Once you run it for a while, they use a tool to expand the pipes for tighter fit. I like the clean look of the slip fit headers.
I am using a mechanical fuel pump on a 408. That's the way it comes from Southern Automotive.
So far, I'm not the least bit concerned with the open diff that came with the car. I have the 17" wheel/tire package. The only time the tires broke loose at all was coming out of turn one. The Nitto drag radials stick like a mutha. Get on the gas, the rear end squats on off you go.
So far the only other thing I would like is the soft-top that I ordered. Hopefully it won't be too long.
One thing about Reg and Frank is if there is anything your not happy with, they will make it right.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
