Chuckbrandt Chuck you need to weld a spacer plate to the opening for the boot to work. 1" to 11/2" width flat steel. works Bent it a little for the curve. Down side is there is no air space to let hot out and cooler in. It will keep the weather out but how many times are you going to drive in the rain or snow?Make sure the lever has full range of travel. Rick Lake
