Few more questions
In regards to the engine selection, assuming this project takes 2-3 years to complete, and you have to nominate engine (for mounts) at the start, and you need to have a current model engine...then your stuffed? Is it an easy thing to do to have the chassis modified for a different engine late in the project? Once the new rules come in in 2005, is that likely to stay the standard for years to come. If so, then will any engine model post 2005 be OK? The LS1 motor...Does the engine mount change from model year to model year, and is it like to change in any future variants?
Also the CR kit sates the body is bonded to the chassis. Is it delivered this way, or are the body\chassis spearate and bonded later? Is it feasable to order the chassis now, and the body at a later date (when needed) or do you run the risk of the company going under and having a bodyless chassis :P? How long has CR been around?
So many questions........
