Thread: Cold wussy ?
Old 11-23-2004, 09:23 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Jeff:
My ERA heater is mounted up under the center of the dash and is has no visible vents other than the defroster vents on top of the dash. The interior vents are 3 spring loaded doors, one each for driver side, pax side and center. Open whichever one you want.
Check the ERA site for the box they use which is only about 9" square but it puts out enough heat to keep the cockpit warm with top and side curtains. Warm enough to operate at less than 40 degrees. In neighborhood traffic I have to turn the blower off to keep the heat down.
Without the top and side curtains I don't think there is a heater made that will keep up.
DonC
