Thread: Dyno numbers
Old 11-23-2004, 08:40 PM
TIGER 6 TIGER 6 is offline
Cobra Make, Engine: SUPERFORMANCE DAYTONA COUPE, 2004, ROUSH 402R,515HP, 500 FT. LBS TORQUE
Thanks for your replies.Bill,I have some data and would like your and others opinion.The data sheet Roush sent with the motor shows 497.9 C Pwr C_Hp at 6000 rpm and 435 CTorq C_FtLb at the same rpm. The engine redline is 6500 rpm so I would assume that the Roush advertised 515 hp is correct. I am not so sure,however,about the 500 lbft torque number. I had the car dynoed several months after purchase on a dynojet.
We did 3 pulls with the following hp/torque results:378.03/389.6, 382/393.01, 385.43/393.34.
As the car did not have rev limiter at the time{does now}, I was shutting it off at ~6300-6400rpm.If I take a 20% reduction in the hp numbers, I should be pulling around 412hp at the rear wheels and 400 lbft of torque. A 15% reduction should result in 437.75hp and 425lbft of torque.
Any thoughts?
