Old 11-24-2004, 03:36 AM
PCC's Avatar
PCC PCC is offline
Default Infernal Jag Inboard Brakes
Okay - I should have known better - British brake design where all of the relaease bolts etc are on the inside including brake lines. Oh no
I need help PLEASE.
I have a rear inboard spewing fluid out so obviously the caliper needs to come off.
Problem is I can't get it off
My Jag friends say that there are two horizontal bolts on the inside (that'll be right). Found one (lower side), but can't see any others!!!!
Released the top two bolts from the handbrake assembly, but caliper only moves upwards (with force).
Where is the infernal second horizontal bolt and if there is'nt one how do I get the thing off - split the caliper
PCC (Peter Craig)
Keep the sun shining
