Old 11-24-2004, 06:08 AM
427 S/O's Avatar
427 S/O 427 S/O is offline
Peter, check my pics, it's probably worth
it to drop the rear end and install the rear mount caliper brackets, I forgot where I purchased the kit but, it came with the E-brake kit as well. Simply pull a cotter pin and use your fingers to replace the pads. There is a another way, I know a fella that cut an access hole behind the seats and installed removeable fasteners to hold
the panel, it works great if you don't want to drop the rear end.
Perry
