Thread: Lobak Mufflers
Old 11-25-2004, 11:31 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default Lobak Mufflers
Hi guys,
It's been quite some time since I've been here, but thought I'd drop a little note while I had the chance.
A while back we had a thread running about choices of different mufflers we could use for best performance VS sound. At that time I had found some inexpensive JC Whitney mufflers that worked great for me and had the sound that I was looking for. We were also investigating the possibilty of Stallion mufflers.
I recently had the chance to talk to the owner of Davis motorsports about trying some Lobak auger type mufflers. He was able to provide me with a custom built muffler 32" long..( what I wanted) with a 7/8" through tube for drafting and the standard auger type muffler that is one of the only Nascar approved mufflers for the new sound emmision rules.
He had a pair to me within 3 days and I immediately installed them. I'm thrilled! The blanks came with no nipples which made installation simple....direct replacements for what I had installed before. The sound is fantastic....deep, throaty and yet with compliant restraint...certainly quiet enough for around town and quiet enough for a freeway conversation with your passenger, but nasty enough sounding for the most ardent hot rodder.
And if this wasn't enough add the performance of a straight through type muffler with virtually no restriction or backpressure. My power increased immediately....and dramatically!
I'm not here to hype as an ad...Don and DV know that I don't, but this man treated me very well and supplied me with a product that I'm very happy with.....You might want to check them out the next time you're thinking about playing with your exhaust.
His URL is http://www.goracin.com/default.cfm ( Is it OK for me to post that here?...If not please edit)
Anyway....Happy Thanksgiving to all of you here....I'm off to a nice cruise to Santa Barbara tomorrow...hope the weather holds!
Best Regards,
Bill
