Chappie is right...plain old contact cement. Brush it on both surfaces (back of carpet and interior body panel) . Let it dry until it is no longer tacky to the touch (usually 15 minutes or so). Then apply the carpet to the interior. A trick I used for larger pieces was to put wax paper on the areas, then peel off the wax paper and stick the carpet as I go. Also make sure you have several new utility knife blades for trimming the pieces
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
