  #26 (permalink)
Old 11-26-2004, 06:56 PM
cobrabuilderI cobrabuilderI is offline
Cobra Make, Engine: Lonestar SVO351W
Yep- right on Ron.
Had the regulator mounted on the frame of vehicle which the guy at the high performance place here in Tampa that sells Holly told me that guys have mounted that regulator that has 2 outputs neat the carb. He said that if I was racing (which I'm not) it would be a volumn problem not using both outputs on the regulator. I'm only using one side. He said that I could take the regulator off and it would has sufficient pressure but I didn't bother and it worked fine. We'll see how this street version works. If you guys could help me with the other situation on the vibration noise- tons of thanks. Cobra owners are the best-
Bruce
