Old 11-27-2004, 09:16 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I had at one time thought of buying one of these trannys to rebuild to a wide/close ratio box, but the cost was prohibitive, as too many parts needed to be replaced, including all gears, as well as the mainshaft, and the tailshaft housing because the shifter mounting bolts were wrong. The only way it made any sense is if I got the tranny for free, but since you already have the tranny, then it may be worth it, but I think you may still be better off just to buy a tranny from dave kee, and sell the one you have.
The gears in the OD toploader have thinner teeth, and/or weaker teeth, than the standard close/wide ratio trannys. The mainshaft is different as well, although it is a 28 spline output.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
