SBF Performance Package
Complete High Performance Kit - $2000
Powder Coated GT40 Intake (302 lower)
Powder Coated Powered by Ford Valve Covers
AFR 165 Heads w/ Ford Motor Sports 1.6 Roller Rockers
Ford X303 Cam
'93 Cobra X3Z EEC-IV w/ Diablo Chip
Pro-M 75mm MAF calibrated for X3Z*
24 lb injectors
Mallory EFI Distributor
* The proper calibration for the X3Z is not 24lbs. It is close to, but not quite 19lbs either. This MAF is calibrated for the X3Z transfer function precisely.
Intake has been shortened and then port matched to upper and these heads. Sweet spot will be VERY slightly higher in the RPM range than usual GT40 intake.
This package will give you bolt on power and bling in one. Be sure to check valve/piston clearance if used on a stock block. I also have a set of hyperutectic pistons that can be fly cut in preperation for the kit. Other stuff:
K&N Conical Air Filter '94+ new $50
Silv-O-Lite Hyperutectic Pistons 4.000 w/pins PN:1177 NIB $90
89-93 Stock EFI Intake new $40
More pictures on request -
All parts are OBO + actual shipping charges from 27615 (NC).
Please send me PM if interested.
Thanks,
Lynn
* www.GT40s.com - Worlds *
* Largest GT40 Community *
