davidlee:
Recommendation noted! However I'm finding that I am occasionally driving along with the blinker going, and feel like an idiot when I finally notice it and turn it off manually. I hate it when I see others doing exactly the same thing, so self-canceling is important to me and my limited abilities.
SecretSquirrel: Frank told me to remove the steering wheel and lengthen/bend down slightly the pin that is sticking out from the steering wheel inner face (and fits in the circular groove in the turn signal mechanism). I inserted a cut-off nail in the hollow pin and bent it down slightly to achieve the desired effect. If you apply either the left or right turn signal (with the steering wheel removed) you'll note a tab rise up at about the 6:30 position in the circular groove. The pin in the steering wheel is supposed to contact that tab and knock it down, which cancels the signal.
So far it is working pretty well.
Let us know when you get yours fired up, it's going to feel great!
Thx
Bill
Bill
"If your work speaks for itself, don't interrupt"
