Stripes - mine a slightly different,. as I left the figures at home and we guessed when in the paint booth...
PCC
Hi Pete,
Yes I know what you mean.
See if I can explain..
there is an 1 and 1/2 difference between the stripe starting at the lip of the dash and finishing under the nose cone.
At the dash lip - just in under above your gauges the stripes are;
7 and 1/2 wide with a 1" gap.
When they get to the nose cone below the
oil cooler position they have reduced to 6".
The rear styripes start at 7 and 1/2 between the seats and go down to 6 and 1/4 wide as the body gets to the back chassis rail under your fuel tank.
We placed the 1" centre lines in first and then ran the others with some guide masking tape to run to.
Now I think if you put 'stripes' in the search you will get the Midstates site with the car plan. It also has the badge positioning plan there.
Now gumballs that another thing..
Bernie
