The epoxy is realativly thick .Is there a thinner coating that could be painted or sprayed on?
Now looking for a tubing bender that will make a fairly tight bend in a 5/16" tubing.
The tools from Willies came . The float tools were almost the same .The bodys looked the same except the checkering was different and and Willies had the hex socket points were radioused. The knobs were made differently . The ProForm inner screw part has a hex head on the steel shaft that the plastic knob is atrtached to .The Willies tool the shaft has a knurled end that the knob is pressed into. But on the table they look almost the same.The power valve tool worked as advertized.
Mike H
