Old 12-03-2004, 07:09 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
Remove your brake lever boot. You'll see two cables, one for each rear brake. Set the rear of the car on jack stands so you can turn each back wheel by hand. Adjust one cable at a time and check to make sure that when the brake lever is released that there is no resistance when you spin the wheel. Anyone can tighten the cables, the trick is to make sure they let go when the lever is released so you don't drive around with one or both brake pads still in contact. You need to adjust them individually or you will never know if they are both set properly. Good luck.
tfarhood
