Old 12-06-2004, 10:02 AM
cheesepocket cheesepocket is offline
Default Upper radiator hose options?
When I originally built ERA 469 I used a hose from the expansion tank to the radiator that is no longer available. I substituted in a similar one, but it is bigger in diameter and at the clamp ends and wants to rub on several things on its way. I have seen ERA cars with a 90 degree steel or aluminum tube, and just rubber clamped a the ends. Is this a tube I can buy from ERA, or where do you get it? Recommended hose PN's for the ends would be appreciated also.
3500 miles and still going strong!
Thanks.
