Thanks. Yea I figured it was a service block with no production code. I didn't know they skipped I... It is a really thick wall block. I can see the difference at the bottom of the cylinder / wall. it looks a good 1/16" thicker all around where the bore meets the area around the bore. It actually flattens out before it turns up.
I knew all the C blocks I'd seen had additional webbing, so maybe CX is additional webbing with thick walls. As you suggest a HD service block.
Well. it seems I have a check to write. Thanks for the insite.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
