At what rpm are you only getting 14 degrees? If it's 2000 take it to 3200... Now what? if it's now closer to 38 total you need to change the springs to the blue or light silver or one of each. What now? If that doesn't work...
There is a provison for you to have the weights locked in, limiting the total advance. Look at the advance plate. Is the red bushing in a small hole limiting its movement? If so your distributor may be locked in. You would have had to have the distributor apart already to have this happen, it's easy to let happen. If the weights are locked in put the advance plate back in 180 degrees from the way you took it out... Your done. Verify the advance curve you like at 1000, 1500, 2000 and 3000... Done
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
