Old 12-12-2004, 08:47 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Default Draining ERA differential
Does anyone have a trick, method or special tool for getting the drain plug out of the differential in the ERA custom rear end with outboard brakes.
Tried the 1/2" socket extension and can get the fill plug off no sweat but the drain plug head is slightly larger than the extension and refuses to budge.
Thanks,
DonC
