Old 12-14-2004, 03:24 AM
Ant Ant is offline
Default FE 427 Rev range
My question is with a serious build, (but max 10.1 comp) 427 engine which would be suitably cammed/manifolded etc to rev to 7000rpm, generally what would be the engines minimum cruising rpm?
This is just to give a very broad approx cruising speed final drive ratio, I also am aware that engines differ quite a bit between builders!
A J. Newton
The 1960's rocked!
