Old 12-14-2004, 01:45 PM
2KWIK4U's Avatar
2KWIK4U 2KWIK4U is offline
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
cbI
Just a thought. There is a vent on the drivers side top axle housing about 4 inches from the center section. When shipped from Currie this vent is capped with a rubber boot. Make sure that you have removed this cap and installed a vent hose that is attached to the frame. If the rearend can't vent, when it warms up it will pressure up and push lube out of the seals.
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
