"Pulled the cable at the trans and spun it with a drill...speedo works."
"Pulled the speedo and spun it from the right angle adapter ...speedo works."
I could be missing something here, but I would say the speedo is NOT the problem in this case.
I would check to see if the gear in the transmisson is correct - I guess you can attach the cable to the tranmission, disconnect it from the speedo, and then drive it and look at the cable to see if it is turning - OR you can leave the cable attached at the transmisson and see if you can rotate the cable by hand at the speedo end.....don't attach a drill and break it! Just turn it by hand...it should turn a little but want to spring back - you'll feel the resistance.
