Thread: Era Fia P203
Old 12-16-2004, 11:59 AM
M. Farcus M. Farcus is offline
Default Era Fia P203
Well used but not abused track car for sale. Third FIA produced by ERA gang. Has ERA rear suspension with outboard rear brakes, Wilwood 4-piston front caliper and rotors. Cooling ducts to front brakes. Electric activated accu-sump, battery cut-off switch mounted behind passanger seat. Custom alumiunm seats, set-up to fit skinny butt, these can be changed out with standard ERA seats. Five point harness for both seats. Eleven pound Halon system mounted in passenger foot box. Puke tanks for fuel tank, rear diff, radiator and motor. Richmond Gear 5 speed and 3.54 rear gear. Current wheels and tires are Phil Schmitt 10.5 and 8.5 pin drives with relief valves, mounted with Goodyear bluestreaks 8's and 6's. Suspension has slightly stiffer coils and sway bars, rear bar is adjustable. Aluminum radiator and custom fan mount. Setrab extra large oil cooler with old style braided lines.
Current motor is out of car for rebuild. I do not build the motors myself, I have a professional shop that I have delt with for years do all the race motors. Any type of motor can be supplied if desired. The paint job was near perfect when the car was new(Blue with orange nose stripe)...that being said, it's whole life, has been as a race car, so the paint is quite "dinged from rocks". The car has run at Sears Point, Lime Rock, Road America, Hallett, & TWS for about 5 years if my math is correct.
The reason for sale is to concentrate all my efforts in Vintage Racing my GT-350 built by Walt Hane, I can't afford to race both unless wife gets a second job.
Roy Allen
rallen@symons.com
