Old 12-16-2004, 02:08 PM
davidlee davidlee is offline
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
Peter,
Don' t waste your time with the tee off of the sending unit idea. I have mine hooked up that way and it doesn't work. The oil temps are always real low because there in no oil flow over the sender.
I looked all over my block {351} trying to find a "good" port but with no luck. The only way to get an accurate oil temp is a fitting in the oil pan or if you have an oil cooler or remote filter in one of those lines.
David
