Old 12-16-2004, 11:34 PM
joea's Avatar
joea joea is offline
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Thanks for the responses. I figured this thing out tonight. I had pulled the cable at the trans once before and checked the teeth on the gear (assuming they were stripped). They looked fine. I then pun it with a drill and the speedo moved fine. Tonight I pulled the gear off the cable and looked at the hole in the gear where the cable connects. This hole should be square. Luckily I had ordered another speedo gear from ERA. When I compared them the new gear clearly had a perfectly square hole. The existing gear had a rounded hole. I'm 99.99% sure this is resolved. Just need to driver her to prove it.
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
