Old 12-20-2004, 06:08 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Ant,
Dean Lampe is building a new 427 and he has purchased the new 600 HP TKO Trans to put behind it. His plans are to go with 3.31 gears (I think he may need to go up even higher gears since his first gear is going to be around 3.27 :1 and final drive gear will be .82 : 1). His plans are to be around 11: 1 compression on his engine. He is also buying the Blue Thunder heads (they are really sweet), Manley SS Valves, dual springs, Victor type intake, Roller Rockers, JE Pistons, with light weight rods. I guess I should let him jump in and tell you exactly what he is doing.
His intentions are to keep his RPM's under 6500 and to use his Cobra in several road race venues each year plus the usual amount of cruising.
Clois
"Let's roll"
"Be part of Something Good
