Thread: 428 vibration
Old 12-20-2004, 08:27 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
It makes no difference how things are balanced as long as they are balanced. The 428 has no more or less issues with balance than anything else with hundreds of moving parts.
That it seems less at higher rpms is more a symptom than a cure. It is still vibrating, and vibrating more, but so is everything else.
You might try removing the pullies rotating them 45 or 90 degrees and seeing if that cures the problem. Quite often during a rebuild they are reinstalled slightly askew. Look for loose or missing or mismatched fasteners (one bolt longer than others) I know this seems pretty picky but it helps. Make sure if the pully looks like it had a weight welded onto it it still does.
It is possible but unlikely you got a vibration dampner off an scj or even a 390 / 427. They are different than a 428. verify the part numbers before you put the pullies back on.
Second to worse case is a misaligned pressure plate, mismatched bolts on the pressure plate can cause the symptoms you describe. A few grams is no big deal at the centerline of the crank but spread that same few grams to the outer edges of the rotating assembly (pistons or flywheel) and it becomes pounds. Worst case is a rotating assembly balance issue.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
