As I mentioned earlier...I've got the steering lock/Ign key where it should be on the column but have also fitted a dash mounted ign switch which is within reach of the ign key harness after inspection.
Regarding the timber dash and you traditional types
I have seen a glass dash laminated with thin timber laminate (real timber) epoxy glued over the glass. The laminate was so thin it would conform to curves etc.
It was then finished off with an epoxy resin specially made for giving a deep gloss to timber...Can't remember the name but next time I'm at Bunnings I'll get the product name as I've seen it there. Bluddy gorgeous stuff over timber, said to be the equivalent to 50 coats of varnish in one coat.
Very pucka pucka in an English sorta way
