Old 12-22-2004, 07:29 PM
Sledge's Avatar
Sledge Sledge is offline
Cobra Make, Engine: BDR #168 427W 66+K miles and counting
Wayne:
Good going man, I'll think about trying that--I hesitate only because it's a bit more work than I had in mind and is probably above my skill level by a notch or two, but I think I now have a couple of weeks off (says he, crossing his fingers). So maybe I'll take a shot at it.
Have you driven yours yet? I just got back home last night so I may have missed some of your posts....
Finally got the thermostat housing leak taken care of and I'm trying to get the air out of the cooling system (I drilled a small hole in the thermostat per other posts, and loosened the water temp sending unit until coolant came out while filling the system) so I should be pretty good.
Question--when the cooling fans come on automatically, should both fans come on or does the system turn one fan on then the other as needed?
Thanks and cheers
Bill
Bill
"If your work speaks for itself, don't interrupt"
